We wish to be able to replicate enterprise geodatabase feature classes and allow 2-way editing of the replicated feature classes. Looking at the possible ways to do this, it appears that there are 3 options:
So, my questions are:
After discussing with Esri Canada staff, it sounds like geodata services will be supported for the foreseeable future, and that the ability to publish them will be added in a future release of ArcGIS Pro. So, it looks like this is the best way to synchronize geodatabase feature classes without having to open a firewall port to allow database access.
Hello Jonathan,
I noticed that 34 people have viewed your post and haven't replied to it. I found your questions intriguing and thought I would take a stab at it.
Without knowing details of your GIS infrastructure, I would venture to say that you are using the traditional versioned geodatabase and your services are hosted from an ArcGIS Server?
Hi Amanda.
Yes, the geodatabases use traditional versioning. The feature services are published to ArcGIS Enterprise 10.9.1 using ArcGIS Pro 2.9. In addition, I've published a geodata service to one of the ArcGIS Server instances using ArcMap 10.8.1.
OK. I would do some research on ArcGIS Enterprise Portal. This will give you the ability to set up branch versioning and also publish feature services in your portal to allow for editing of a feature service. The reconciliation process happens at the feature service level with permissions that you set on the feature service when published. The nice thing about Enterprise Portal is that you don't have as much maintenance on the geodatabase side (no needed compression, etc.) because it is all done on the feature service by the end user.
For your question about geodata services being legacy... it not so much that the concept is legacy, but the workflow is evolving with the new technology.
Check it out here: https://enterprise.arcgis.com/en/portal/latest/administer/windows/what-is-portal-for-arcgis-.htm
Thanks for sharing! Our agency uses scenarios #1 and #2 extensively. If it is helpful to you, I'm hoping Esri soon provides a bit more support for geodata services within Pro so that traditional workflows can continue with ease (for a least a while longer). After I submitted this to Esri, their support confirmed it as a bug. There is hope for even more replication support in Pro!
