Pro 2.9.1 - I have a mapbook that now crashes when you try to export anything, it either hangs forever, as in 48 hours later still grinding away with no progress, or sometimes it crashes to the desktop. Same results if done with the series export as with the standard single sheet export. So I need to use Python to export anything now. What's the simplest way to export a map series via the Python window?
