Is there a way for two people to collaborate on the same vector basemap? It seems like even if it is saved within a group, there is still no way for someone else to edit - would a Shared Update group work?
@GlennIngram We are able to confirm this workflow to have members of the same Organization edit the same style:
- create a group or use an existing group, add all the members that you want to access the style
- create a new style or edit an existing style. In My Content -> Layers -> Tile Layers, select the style you want shared.
- Click the Share button, on the Share modal, select Edit Group Sharing button, and share the item with your group
- In order for other members of the group to see this item, the can refer to it by its ItemID, or each member can go to Content -> My Groups, then select the group, and the Tile Layer should appear.
- You can load the tile layer in the Map Viewer Classic, and then the style editor icon will appear in the legend
The user must have the Publisher role or greater for this to work.
