I would like to be able to set a background color to a specifik text element.
I think it would be a good possibility to highlight parts of the text.
I'm attaching two images with examples of what I mean.
@OwenGeo I assume you mean if we had an equivalent block in ordinary Stories that actually shows in the published story? In that case it could meet our use case, but I would like to be able remove or config the "i-symbol" in the corner and be able to use at least a couple of different background colors.
@Blihack @MattiasEkström -- I'm not sure if this would meet your use cases, but the recently released template feature has an "instruction" block that has a background color. Would this work?
Getting started with templates in ArcGIS StoryMaps
Hi @OwenGeo, are there any updates on this feature request? It would be helpful for my organization as well.
Thanks for the tip, I have tried that quote style, but I want more alternatives for highlighting parts of the text.I want to use the quotes for actual quotes, and still be able to set backgroud color on text that can be both small or large paragraph or lists etc.
This is similar to that quote style in storymap themes where text is overlaid on a rectangle filled with color.
Have you tried that quote style?
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer gratis.
