The map within an ArcGIS online dashboard is set to show a layer visibility toggle and a legend widgets. The content is missing or shows incomplete within the two widgets. Please see the attached images.
We have quite a few dashboards published and in use, this is the first time that I see this problem. The same issue is occurring in another dashboard I am currently preparing, using different datasets, so the reason is likely not in the data.
Just to check: is it simply that the text is white and blends in with the widget background? I would try adjusting the dashboard theme to see if it changes.
Thank you @jcarlson . This was the reason.The setting for the map window background does not apply to map widgets background, however the setting of the text colour does. Ideally, we should have the two settings (background and text colour) apply to both map window and widgets. Or, have a separate settings for the map widgets.
