Hello, I'm using ArcGIS Online.
My task at hand, is that I've uploaded a Layer of Points on my sample map.
From those points, I'm trying to determine two things
1) of the points, which points are within, a Flood Zone, and filtering points that are "out" to only focus on the points that "are not" (Layer is available as "FEMA National Flood Hazard Layer" through ArcGIS Online)
and
2) of the sites not within a Flood Zone, which are within a proximity, say 500' of another available Layer called TCEQ Water Districts. (Layer is available through Arcgis Online Community called "TCEQ Water Districts")
Any examples you can provide, or summary tutorials, even with just a small data set would be very helpful.
Unsure if both of these analyses can be on the same "Map", or if they should be separate & then merged in a subsequent map.
The goal is to extract a list, to export (ex. to Excel) of points that are not within a floodzone, and those that are within 500' of a Water District.
Thanks, Will
