Here is some code to create the checkbox list. However, when i pan the map the check boxes in the list become unchecked. Is there a way to stop this from happening?
function buildLayerList() { require(["dojo/on", "dojo/dom", "dojo/_base/array"], function (on, dom, arrayUtils) { var mapLayer = map.layerIds; var myItems = []; arrayUtils.map(mapLayer, function (layerName) { var myLayer = map.getLayer(layerName); if (myLayer.id !== "NAIP2012" && myLayer.id !== "NAIP2009" ) { if (myLayer.visibleLayers) { //console.log(myLayer.id + " : " + "has vis Layers"); var items = arrayUtils.map(myLayer.layerInfos, function (info, index) { if (info.name === "Label SEO wells by depth" || info.name === "Label SEO wells by actual yield" || info.name === "Label SEO wells by MWBZ top") { // console.log(info.name); } else { if (myLayer.visibleLayers.indexOf(info.id) > -1) { return "<input type='checkbox' class='list_item'" + (info.defaultVisibility ? "checked=checked" : "") + "' id='" + info.name + "CB'' /><label for='" + info.id + "'>" + info.name + "</label><br>"; } } }); myItems = myItems.concat(items); } } }); var ll = dom.byId("legendDiv"); ll.innerHTML = myItems.join(' '); document.getElementById("legendDiv").style.display = "block"; }); }
I am calling on the buildLayerListin the map:
mapLayer.on('update-end', buildLayerList);
<script type="text/javascript" src="javascript/layerVis.js"></script>
if(map.loaded){ initUI(itemInfo); } else{ dojo.connect(map,"onLoad",function(){ initUI(itemInfo); }); }
function initUI(itemInfo) { //add theme for popup dojo.addClass(map.infoWindow.domNode, "chrome"); var scalebar = new esri.dijit.Scalebar({ map: map, scalebarUnit: "english" //metric or english }); displayLayerList(itemInfo); }
