I'd like to see a new and relatively simple widget in ArcGIS Dashboard. It's a analog (or digital) clock. One of my users is going to show the dashboard on a big screen in their office, and wants to see the time.
@OznurGeze Totally! Assuming you had the "end date" either determined by your data, or just hard-coded into the expression, you could easily adjust this to show a duration, a remaining time, etc.
It is amazing! Could you do countdown with this too? Is it possible?
You can combine a data expression with some SVG elements to create a clock of your own, too.
Data expression:
var n = Now() var thehour = Hour(Now()) var theminute = Minute(Now()) if (thehour > 12){ thehour -= 12 } var out_dict = { fields: [ {name: 'thehour', type: 'esriFieldTypeInteger'}, {name: 'theminute', type: 'esriFieldTypeInteger'}, {name: 'hourdegrees', type: 'esriFieldTypeDouble'}, {name: 'minutedegrees', type: 'esriFieldTypeDouble'}, {name: 'ampm', type: 'esriFieldTypeString'}], geometryType: '', features: [ {attributes: { thehour: thehour, theminute: theminute, hourdegrees: thehour * 30 + (5 / theminute), minutedegrees: theminute * 6, ampm: Iif(Hour(Now()) > 12, 'PM', 'AM') }}] } return FeatureSet(Text(out_dict))
HTML:
<p style="text-align: center"> <svg height="300" width="300"> <circle cx="150" cy="150" fill="grey" r="130" stroke="black" stroke-width="3" ></circle> <path d="M150 150 L 150 40 Z" stroke="white" stroke-width="3" text-align:center="" transform="rotate({minutedegrees},150,150)" ></path> <path d="M150 150 L 150 60 Z" stroke="white" stroke-width="5" transform="rotate({hourdegrees},150,150)" ></path> <text x="150" </svg> </p>
You could also embed a clock from elsewhere: https://24timezones.com/clock-widget
This is a little hacky, but you could create an Indicator widget and put this in for the Advanced Formatting expression:
return { topText: 'Current Time', topTextMaxSize: 'medium', middleText: Text(Now(), 'HH:mm') }
Then set the refresh interval to 0.1 minutes, and your indicator will look like this:
Analog would be trickier, but I still wonder if you couldn't mangle a Gauge or two to do it for you with a Data Expression.
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer gratis.
