the Portal for ArcGIS is upgraded to 10.9.1 after upgrade the post upgrade is hand and unable to complete
Please suggest on the resolution
I am sending the logs o
from the logs I do not see anything in particular.I'm wondering, are you using IE?if so, I recommend using Chrome, Firefox or Edge.
Same problem here. We are using the new Microsoft Edge. @JonathanQuinn can you please help? how can we trigger again the post upgrade window to our portal? To start the process again?
Edit: Linking another post here: Upgrade high available portal from 10.8.1 to 10.9.1 in windows
@PrasadJ we found a solution from our side. We had 2 issues:
I hope you have found a solution for your case.
