I need to install the open-source ArcSDE 10.3 on windows.
Could you please share the steps to follow?
This might help:
https://community.esri.com/t5/esri-technical-support-blog/where-is-the-install-for-arcsde-10-3/ba-p/898330
I don't find the installation ArcSDE 10.3 package on the mentioned link. Can u pls advise?
As Amanda mentioned, there is NO install for ArcSDE 10.3 or newer version.Those files have been replaced with built-in functionality in the ArcGIS clients / Python / Toolboxes.What are you needing from the ArcSDE install?
1) I used the below code to the SDE 10.3 direct connection from java
String instance = "1234";//sde portString server="host";
if (conn == null) {try {conn = new SeConnection(server, instance, database, userName, password);System.out.println("Connection Successful");
I got the below error
[java.lang.UnsatisfiedLinkError: no sdejavautil in java.library.path] with root cause
I have to install the ArcSDE 10.3 on my local machine so that I can able to avoid this issue.
