Hi all,
Upgraded ArcPro 2.9.0 and its crashing when using Select by attribute process. I have tested it with different datasets but getting the same results.
Any recommendations would be helpful.
Hussain
Tech Support would be best since there must be something fundamentally wrong since I don't see any error reports that are public
Hi @DanPatterson ,
Just wanted to update on you, I have installed the new copy of the ArcPro 2.9 and its still crashing on me. so I am going back to 2.8 for now.
No, not yet. I am out of the office for Christmas, and I will update you once I am back in the office.
H
Did you get this resolved?
Thanks @DanPatterson , I will give it a try.
If it just crashes without any error, then you probably have a bad install.
Try Add/Remove Programs (windows), Select "Remove" then "Repair". A reinstall will be attempted.
Should that not work, then you will have to reinstall completely from the *.msi if you downloaded and saved the *exe and installed from it
