Hi, I imported a geodatabase as an online feature server and made it's sharing settings as public. The gdb does not have any features in it. But it does contain the schema information including all layers and attributes of layer. The same I can see on QGIS when trying to access the feature server. However from runtime Java API all layers of the feature server fail to load. I get load status as FAILED_TO_LOAD.
I can even see the layers when I directly open the feature server URL and attributes when I open the layer URLs on web browser. All I'm able to get is name of the individual layers. But I need the fields also.
Also using the same code for loading feature tables, I'm able to load other feature layers that I was testing. But this feature server layers fail to load. The give the load error message as 'Invalid Arguments.'
The feature server url is :
https://services1.arcgis.com/owfRSBecxmXo3S0X/arcgis/rest/services/roads_database_ver_411gdb20211207t151917z001/FeatureServer
This is a public layer and requires no authentication.
