I have a model builder process that will create a shapefile, that later is retrieved by another process. The other process requires a zip file input. Is there any way I can zip up these files within model builder?
Improved, skipping the zip to avoid trying to write it into itself:
import os import glob import zipfile def zipshape(folder, name): os.chdir(folder) zipname = name + ".zip" flist = glob.glob(name + ".*") with zipfile.ZipFile(zipname, "w") as newzip: for ff in flist: if ff[-4:] != "lock" and ff != zipname: newzip.write(ff) return os.path.join(folder, zipname)
UPDATE: added check to loop to avoid trying to write the zipfile into itself and causing an infinite loop (!) (discussed downthread) UPDATE: this function requires the two inputs folder (path to the shapefile) and name (shapefilename, for example if your shapefile is foo.shp, the name should be foo (without the extension)
import os import glob import zipfile def zipshape(folder, name): os.chdir(folder) zipname = name + ".zip" with zipfile.ZipFile(zipname, "w") as newzip: for ff in glob.glob(name + ".*"): if ff[-4:] != "lock" and ff != zipname: newzip.write(ff) return os.path.join(folder,zipname)
Good solution, solved my process. Thanks.
@curtvprice Thanks a lot I can create zip file right now. Just one question do you know how can rename the zip file which I created rename with current date land_TodayDate.zip.
I created shape file and added date whenever you run the model. Right now I am trying to zip the shapefile and then next step rename it like this : "A_todaydate"
I don't understand this part. what I need to replace. how can I get already shapefile created and zip it.
The modelbuilder wrapper I set up asks for a path and a shapefile root name. I will update the function doc to make that clear. For example, your call above assumes you have a shapefile E:\mypath\open.shp
HelloI can create zip file but the zip file is empty.zipshape(r"E:\mypath","open")
The process "calculate values" seems to have created the zip file just fine, but the model builder is stuck on the step. The zip file was created and has not changed file size for about 20 minutes. See screen shot:
I can't understand what would hang it up.
I want to stay in model builder, but if the other solution does not work, I will try this one. Thank you for your contribution. I am sure it will benefit someone, whether its me or another down the road.
OK. I will try it and let you know how it goes.
Honestly I can't think of an simpler way to do this.
This is a plug and play python function, you don't need to edit it at all, just create a calculate value tool and paste the code in the code block, and make sure the variables (inside the %) match the model variables that have your folder and shapefile name. The function doesn't care as long as you give it the correct folder and shapefile root name, which is easily found with Parse Path. I suppose you could enter your folder and shapefile name directly in the Calculate Value tool expression in place the model variables...but Parse Path makes it pretty easy to avoid having to hard-code it.
See below for the batch file script that I use to zip up the files. You will have to download 7Zip software to make it work. Put this in a text file in notepad and then save it as a .bat. I run it in Windows Task scheduler behind the script that prepares the text files.
:: Zip TxtFiles in DATA\TEXT folder@echo ON
SET SourceDir=K:\GIS_UPDATE\DATA\TXT*.txtSET DestDir=K:\GIS_UPDATE\DATA\TXT\MCPAEXTRACT.zip
CD /D "C:\Program Files\7-Zip"7z.exe a "%DestDir%" "%SourceDir%"
I am not yet great at python, so simple is better. If I already know what the full path and shapefile name is always going to be, how would this look simplified?
You can do this using the Calculate Value tool, with a python function that uses glob and zipfile. You may want to run Parse Path first to get the info you need to create the zip (folder, shapefile root name).
Hello Matthew,
I have a similar process but it is handled using a combination of a python script to prepare the data and then a batch file script to zip the contents of the folder. I can share it with you if you like.
