In Field Maps, I have set up a subtype so that I can control the values available in following fields.
So, if they add a sign, it will ask what type, if "Warning" is selected, the next field will only show the values from Wcode domain, if they pick "Regulatory", the next field will only show values from the Rcode domain and so on.
This seems to be working properly, however, if they pick "Warning", they get the Wcode list for the next field (as expected), now, if they change the subtype to "Regulatory", it still only shows the values from the Wcode field, not the Rcode field as set up in the SubType.
The only way I have found to get it to update is to abandoned that feature, discard edits, then add a "new" feature and pick the "Regulatory" SubType on the first go.
Anyone else run into this and have a solution?
R_
