I'm trying to publish a storymap I've been working on, but every time I try it says "sorry, there was a problem publishing your story map". I don't know why it's doing this. Every other feature of the story map is working fine.
I'm having the same issue - the error message is very vague - I looked at sharing story and map permissions, all seems good...
We are having the same issue on a shared story map.
I'm running into the same issue with a story map that was already published. I'm trying to publish again (after making a minor change) - "sorry, there was a problem publishing your story map".
I went through my webmaps with a fine tooth comb...There was a featureclass in one of the webmaps that had been republished in Pro. When I opened the map it alerted me that that featureclass couldn't be added to the map. I added it again, and now it publishes.
I am having the same issue now. Has there still been no solution to this error message on StoryMaps?
