Hi, I'm using Pro 2.8.2 and Spyder 5 as my IDE. Adding Seaborn to a cloned environment breaks Pandas. When I try to import Pandas I get an error (see below); importing Seaborn causes a similar error. Any thoughts?
Chris
In [1]: import pandas
File "<ipython-input-1-38d4b0363d82>", line 1, in <module>
import pandas
File "C:\Users\user.name\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone1\lib\site-packages\pandas\__init__.py", line 22, in <module>
from pandas.compat import (
File "C:\Users\user.name\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone1\lib\site-packages\pandas\compat\__init__.py", line 23, in <module>
from pandas.compat.pyarrow import (
File "C:\Users\user.name\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone1\lib\site-packages\pandas\compat\pyarrow.py", line 9, in <module>
_palv = Version(_pa_version)
File "C:\Users\user.name\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone1\lib\site-packages\pandas\util\version\__init__.py", line 339, in __init__
match = self._regex.search(version)
TypeError: expected string or bytes-like object
