Hey, installed custom npm library, then i run ArcGISExperienceBuilder\client> npm start
it fails on many libraries:
ERROR in ./your-extensions/widgets/simple-lg/node_modules/debug/src/node.js 5:12-26
Module not found: Error: Can't resolve 'tty' in 'C:\Downloads\arcgis-experience-builder-1.6\ArcGISExperienceBuilder\client\your-extensions\widgets\simple-test\node_modules\debug\src'
BREAKING CHANGE: webpack < 5 used to include polyfills for node.js core modules by default.
This is no longer the case. Verify if you need this module and configure a polyfill for it.
If you want to include a polyfill, you need to:
- add a fallback 'resolve.fallback: { "tty": require.resolve("tty-browserify") }'
- install 'tty-browserify'
If you don't want to include a polyfill, you can use an empty module like this:
resolve.fallback: { "tty": false }
