Hello I have a Feature Layer with three integer fields (A, B, and C)
I want to calculate the percentage between A and B. The following will run but I only get values of 100 or 0. Nothing in between, and manual calculations prove that there are valid values between 100 and 0.
overlay_result_layer.calculate(where= "1=1",calc_expression={"field": "C", "sqlExpression":"(B/A)*100"})
Can anyone see what is wrong with my syntax?
For additional info, I run the calculation below right before without errors perfectly fine;
overlay_result_layer.calculate(where= "1=1",calc_expression={"field": "B", "sqlExpression": "D * 247.105"})
