I'm trying to extract the buildings from a point cloud and get the following error:
Adding roof form field domain...
DescribeData: Method domains does not exist
Error on line 2363
Error in file name: C:\temp\3DBasemaps\scripts\bm_common_lib.py
with error message: AttributeError: Object: Error in parsing arguments for Exists
Failed script Extract Roof Form...
ERROR:root:Error on line 2363
I think this is because of this part of the script "extract_roof_form.py" (lines 2363 and 2364):
if arcpy.Exists(output_fc):
arcpy.ClearWorkspaceCache_management()
because Clear Workspace Cache only works with enterprise geodatabase workspaces.
When I commented line 2364 I was able to complete the task without errors. But this not always works.
I'm using ArcGIS Pro 2.8 and the latest solution. Any help will be appreciated.
Best regards,
Peter
