Is it possible to display 'or other' selections made on feature reports? If not, is there an alternative way to show this information on a feature report?
"just call either question 1 or question 2 on the Feature Report"
No you create a 3rd field in the form that takes field 1 if not other and field 2 if other. That way field 3 always has the data in it and no need to worry again (late in data analysis people will not know to search 2 fields so it is a constant pain). In the form set the bind esri column to null for both field 1 and 2 then they will never show in the feature service so no one can even tell you did the trick.
Hope that helps
Yea just the pain there is if later you search for something or do a filter you have to search both fields every time.
So I actually found an alternative for what I was looking for. I did not realize that under the Schema tab in Survey123 Connect, the 'other' fields have a field name (ex: project_manager_other). I was able to just add ${project_manager} ${project_manager_other} to my feature report to get both responses to show without a third field in my form. That being said, when the Other option is selected, the output on the feature report now looks like:
"Other Joe Schmoe" instead of just "Joe Schmoe". Ideally I'd just like the "Joe Schmoe", so trying to figure out if I can do that now.
Do you mean set it up as 2 questions basically in the survey? Ex: Here is my question, options in the drop down are 1, 2, 3, other. If Other is selected, another question comes up for 'Other Response' and then I just call either question 1 or question 2 on the Feature Report with relevant fields? I'm hoping to avoid adding questions to my survey
For or other questions the 3 field trick is usually what people want.
Field 1 is the drop down. Field 2 is the other value. Field 3 takes 1 if it is not other and 2 if it is other. That way all the values are in one field. Set 1 and 1 to bind null and you never even see them.
You may want that instead. Having data in 2 fields is always a pain. Hope that helps
