I run into this error when importing Python modules to ArcGIS Pro 2.8.
Its last line is: Typeerror: expected string or bytes-like object.
Anyone has any ideas to sort this out?
Thank you.
Thank Dan,
The same error message appeared, unfortunately. But thank you for trying to help. I really appreciate your contribution.
Anyway, I have sorted it out. I have just remembered that a few weeks ago, I cloned the Python Environment in ArcGIS to install Deep Learning Libraries. Unfortunately, I have not finished the process and the cloned Python Environment was activated. So, i guess the system could not locate the folders of the cloned Environment (it, by default, directed to folders of the installed Python Environment). So, what i did was just activating the installed Python Environment in the Setting and restart ArcGIS application. Everything works fine!
Thank Dan.
do the import one at a time.
import os
then
import arcpy
import arcgis
import pandas
what is the message if it fails again? (doing it one at a time narrows down the issue list)
