I am having trouble getting double symbology in ArcPro. When I'm in 'Vary symbology by attribute', the fields are limited to only a few, & not the ones I need. Any help would be appreciated!
Again.... Attribute-driven symbology—ArcGIS Pro | Documentation
is everything enabled? What are the field types? are there any joins? if there are joins, did you try to make the join permanent?
Yes, everything is enabled. No joins. The fields are text (not showing) versus Long or Double. I'm just trying now to create a new field for what I need in Long or Double. Here goes...
That didn't work, as I need it to be a text field. It looks like that could be the reason why though, 2nd symbology can only be numerical? Any ideas??
show what is in your table and what fields you are using so people can try to replicate your steps
That's right! Does not work with the Text field; BUG-000104316! More about Setting up the attribute-driven color in symbology... - Esri Community
