I'm trying to perform the Create Watersheds and Upstream Watershed tool from this Esri tutorial (linked below). This has worked in the past, but now it just processes "spins" and never produces the layer. I assume this is an issue with Esri...
http://learn.arcgis.com/en/projects/no-dumping-drains-to-ocean/
Thank you for your help.
Hi Bryan,Have you since encountered issues with this workflow? Have you checked to see if the result layer was added to your contents, but not the map?-Amanda
