Hello!
I am in the process of making forms with Field Maps and using default values to do so. In the process I found the Zone Lookup App, and my question is, can you input the value from the polygon into a field as a default value?
For example: my workflow requires users to fill out forms while inspecting utilities such as manholes and electrical poles, one of the questions the users must full out is a "Priority of Area" question. (this question helps us determine what utility should be prioritized) I want to submit a point (via Field Maps) and based on the area (in this case a polygon) have the default priority from said polygon show up in the "Priority of Area" question.
Can this be done? I am new to the world of GIS and coding and I am eager to learn!
Thanks!!
