Hi All,
I am trying to use Data Driven Pages to create Tile packages (TPK) instead of outputting to a PDF or JPG. What I am finding that as I iterate through the pages, the TPK's don't honor the definition query set by the Data Driven Page. In my use case, I am iterating through every floor of a building and trying to write out a TPK (instead of PDF) for every floor.
Is this possible or can you only export to an image?
Here is my Python Script:
import arcpy, os, argparse
parser = argparse.ArgumentParser(description='Export TPK')
parser.add_argument('-inMXD', help='input map document setup for DDP', required=True)
parser.add_argument('-outFolder', help='output folder name where TPKs will be written', required=True)
args = parser.parse_args()
strOutpath = args.outFolder
mxdPath = args.inMXD
#Test if inMXD exists
if os.path.isfile(mxdPath) and os.access(mxdPath, os.R_OK):
print "input MXD found ( " + mxdPath + ")"
else:
print "Can NOT find input MXD: " + mxdPath
exit()
#Test if outFolder exists
if os.path.exists(strOutpath) and os.access(strOutpath, os.W_OK):
print "Output folder found (" + strOutpath + ")"
else:
print "Can NOT find output DDP folder:" + strOutpath
exit()
mxd = arcpy.mapping.MapDocument(mxdPath)
for pageNum in range(1, mxd.dataDrivenPages.pageCount + 1):
mxd.dataDrivenPages.currentPageID = pageNum
pageorder = mxd.dataDrivenPages.pageRow.FloorID
#Building Value
buildingVal = mxd.dataDrivenPages.pageRow.getValue("BUILDINGNAME")
#Floor Value
floorVal = mxd.dataDrivenPages.pageRow.getValue("FLOOR")
OutputPath = strOutpath + "\\" + buildingVal + "\\" + floorVal
arcpy.env.workspace = OutputPath
#Get DataFrame
df = arcpy.mapping.ListDataFrames(mxd)[0]
print("Packing " + OutputPath + ".tpk")
arcpy.CreateMapTilePackage_management(mxdPath, "ONLINE", OutputPath + ".tpk", "PNG8", 24,"","","",df.extent,75,"tpk",0)
del mxd Thanks!
