Hello @RafaelCelaya,
If you are applying a filter to a field in a repeat we have an issue logged regarding this error. We are working on a fix for the issue, in the meantime please feel free to reach out to Esri Technical Support and have them attach you to BUG-000143323 to track progress on the issue.
just wondering if you found a workaround. I am trying to pull out only the First Attachment from a survey123 form to show in a popup and get the same error
It is working for me. Thank you so much!
Hi @Travis_GIS
This might be an known limitation, by default, the report will show the filtered records in the parent table, and all the related records of them in the related tables.
You could use a where filter in your report template to filter the record in the related table, here is the syntax: ${#layername | where: } ... ${/}
Please let me know if this is not the case.
Ruth
Hi @RafaelCelaya @Anonymous User @FredMitchell
The fix for this issue is now available on the production website, if it is possible please help us verify the fix, and let us know if you have any question.
Hi @ZacharySutherby
I had some clients today that tested with this beta version and now the filters are working just perfect!
FYI, the Audit Date filter is within the repeat, the DateReport filter is not. Also, the filter works and is applied in the attribute table, however, when I run a report, the filter is not applied.
This is not working for me even in the Beta website. I'm no longer getting the error when trying to generate the report which is great...but the report output doesn't seem to apply the filter appropriately. Here is my applied filter and the resulting output in the report where it is still showing all audit records despite my filter (I only want to see audit info for 2021):
It works great!
There's a typo in the link from Zach...remove the 2 before beta and it will work!
I cannot access this webpage... it gives the response :"Hmmm… can't reach this page".
@ZacharySutherby yes! I just tested my survey and it works great in the beta website. When will this release be available on the main site?
Hello @RafaelCelaya @Anonymous User @FredMitchell,
We have a fix for this issue in plan for our 3.13 October update, the fix is currently on our survey123beta website. If we may ask, please test on https://survey1232beta.arcgis.com and let us know if the behavior is still present there.
I am also getting this error trying to filter data in Survey123 but not in a repeat. TypeError: Cannot read properties of null (reading 'currentVersion'). @ZacharySutherby are there any updates on this?
I am also having this issue when trying to filter by related data within Survey123. Does anyone know if there has been any update on this?
Thank you Sir, I will reach out to Eris Technical Support.
