Hi
I have a tiled map service. I,m going to add opacity controller for this layer, but I can't!!
this is my code:
<SPAN class="keyword token">var</SPAN> housingLyr <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">TileLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
url<SPAN class="punctuation token">:</SPAN> <SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=http%3A%2F%2Flocalhost%3A6080%2Farcgis%2Frest%2Fservices%2Fhousing%2FMapServer" target="_blank">http://localhost:6080/arcgis/rest/services/housing/MapServer</A><SPAN>"</SPAN></SPAN><SPAN class="punctuation token">,</SPAN>
id<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"ny-housing"</SPAN><SPAN class="punctuation token">,</SPAN>
visible<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">,</SPAN>
opacity<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">1</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="operator token"><</SPAN>body<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>span id<SPAN class="operator token">=</SPAN><SPAN class="string token">"layerToggle"</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>input type<SPAN class="operator token">=</SPAN><SPAN class="string token">"checkbox"</SPAN> id<SPAN class="operator token">=</SPAN><SPAN class="string token">"housingLyr"</SPAN> <SPAN class="operator token">/</SPAN><SPAN class="operator token">></SPAN>satellite layer
<SPAN class="operator token"><</SPAN>input id<SPAN class="operator token">=</SPAN><SPAN class="string token">"opacity"</SPAN> type<SPAN class="operator token">=</SPAN><SPAN class="string token">"range"</SPAN> min<SPAN class="operator token">=</SPAN><SPAN class="string token">"0"</SPAN> max<SPAN class="operator token">=</SPAN><SPAN class="string token">"1"</SPAN> step<SPAN class="operator token">=</SPAN><SPAN class="string token">"0.1"</SPAN> value<SPAN class="operator token">=</SPAN><SPAN class="string token">"1"</SPAN> <SPAN class="operator token">/</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>span<SPAN class="operator token">></SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
