Hi everyone,
I had an issue with publishing a webapp through ArcGIS Online a month or 2 ago. Everything was fine until it suddenly required organization access login. From the forums here, I was able to see it was due to some layer that was no longer publicly shared or was pulled from the hosted server.
I tried to deduct which layer it was by removing layer by layer at a time, only to see even after removing all layers, it was still requesting a login! This made me think it was pulled from the hosted server, so it would no longer appear in my web map and webapp, but would still cause the login issue. However, if that is the case, how am I supposed to remove the layer causing the issue if it no longer appears in my web map or web app?
Any advice would be greatly appreciated, as this is a concern of mine while working on future web apps, and is making me wonder if back-ups are necessary in case this happens again.
Thank you,
Alex
