Allow users to set defaults in the 'move to' tool. I am editing and replacing thousands of building models and must change the method to delta in map and scene every single time. a default setting option would be helpful.
In ArcGIS Pro 3.0, the last used method is remembered during the Pro session and the setting is shared across all maps in project. We think this will alleviate the stated problem.
See Ideas in ArcGIS Pro 3.0 for all of the other ideas you can look forward to when you upgrade.
Also be sure to check out the What's New documentation: https://pro.arcgis.com/en/pro-app/latest/get-started/whats-new-in-arcgis-pro.htm
Much appreciated. Cant wait to use it.
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer gratis.
