Hello everyone,
I'm currently using ArcGIS 10.5. I was wondering if there is a tool that automatically adjusts a polygon to a specified size? Say I start with a triangle of 3 hectares, and I want to increase its area in all directions for it to become 5 hectares automatically, is there a tool that does this? Or a combination of tools perhaps?
Thank you
I did come across this bit of code, which may help:
import arcpy import math def scale_geom(geom, scale, reference=None): """Returns geom scaled to scale %""" if geom is None: return None if reference is None: # we'll use the centroid if no reference point is given reference = geom.centroid refgeom = arcpy.PointGeometry(reference) newparts = [] for pind in range(geom.partCount): part = geom.getPart(pind) newpart = [] for ptind in range(part.count): apnt = part.getObject(ptind) if apnt is None: # polygon boundaries and holes are all returned in the same part. # A null point separates each ring, so just pass it on to # preserve the holes. newpart.append(apnt) continue bdist = refgeom.distanceTo(apnt) bpnt = arcpy.Point(reference.X + bdist, reference.Y) adist = refgeom.distanceTo(bpnt) cdist = arcpy.PointGeometry(apnt).distanceTo(bpnt) # Law of Cosines, angle of C given lengths of a, b and c angle = math.acos((adist**2 + bdist**2 - cdist**2) / (2 * adist * bdist)) scaledist = bdist * scale # If the point is below the reference point then our angle # is actually negative if apnt.Y < reference.Y: angle = angle * -1 # Create a new point that is scaledist from the origin # along the x axis. Rotate that point the same amount # as the original then translate it to the reference point scalex = scaledist * math.cos(angle) + reference.X scaley = scaledist * math.sin(angle) + reference.Y newpart.append(arcpy.Point(scalex, scaley)) newparts.append(newpart) return arcpy.Geometry(geom.type, arcpy.Array(newparts), geom.spatialReference)
You can call it with a geometry object, a scale factor (1 = same size, 0.5 = half size, 5 = 5 times as large, etc.), and an optional reference point:
scale_geom(some_geom, 1.5)
Referenced from here:
https://gis.stackexchange.com/questions/169694/is-there-arcpy-tool-for-polygon-resizing-like-scale-tool-of-advanced-editing-too
Maybe this is what you could use:
https://desktop.arcgis.com/en/arcmap/latest/manage-data/editing-existing-features/scaling-a-feature.htm
https://pro.arcgis.com/en/pro-app/2.6/help/editing/move-or-rotate-or-scale-a-feature.htm#GUID-9E6FCFDA-84A6-4D3B-BDF1-3F248166F554
Dear Mark,
Thanks for the response!
Although my problem with this tool is that I don't seem to end up with the exact measurement I want. You will see in the first image that the polygon is 0.890589 hectares. I wanted to upscale this to 0.9494 hectares by using 1.06571298 as the Scale Factor. You will see in the next image that I didn't arrive at this and instead got 1.011788. I'm not sure what's happening here but this tool can't seem to help me with what I want to happen. Any other solutions you can suggest?
Before Scale ToolAfter Scale Tool
I am unsure why the tool behaves in that way. It might be worth raising a support ticket to see if there something that can be done.
I cant' think of any other OOTB tools that can help you with your problem. You could probably code something up in Python to do the job though.
Hello again Mark,
Maybe I can bring it up with them. Unfortunately, I don't know enough Python to construct a code that will execute said task. I may have to wait for a response from esri regarding the tool.
Thanks for your responses 😁
