Hi everyone in the Community.
I'm developing an Angular application using Typescript and ES modules syntax, but I'm facing a problem when I try to define some ArcGIS objects taking source from sample API application on Esri website.
For example the following code fails:
import Point from '@arcgis/core/geometry/Point';
const point: Point = {
//Create a point
type: 'point',
longitude: 12.600913,
latitude: 42.55151,
};according to following pages on API documentation:
https://developers.arcgis.com/javascript/latest/add-a-point-line-and-polygon/
https://developers.arcgis.com/javascript/latest/api-reference/esri-geometry-Point.html
but just at editing time I got this error:
error TS2740: Type '{ type: "point"; longitude: number; latitude: number; }' is
missing the following properties from type 'Point': m, x, y, z, and 21 more.
Same behaviour occurs if I define in different ways the object.
May any of you explain what I'm making wrong and how to solve it?
Thanks in advance and best regards.
