Sinds de laatste update ondervinden we de volgende problemen-:<\/P>
I too am having similar issues, and am concerned as to what these disruptions might mean for published reports. A strange one I'll add to the list, but is related to a few of the mentioned issues:
No fix on my end yet either, unfortunately.
I would like to surface this issue and add a few more comments as well. The new update has thrown off a lot of our reports and it has been really frustrating trying to deal with all the issues that have popped up. And the fact that the visual has been jumping back and forth between the new and old version has resulted in us having to fix our maps several times. Some of our many issues are listed below as follows:1. My boundary map (which uses SA1 levels) no longer works and is stuck in an infinite loading loop and the visual simply displays unintelligible triangles. 2. Within the boundary map, the settings keep changing to the default ones every time a slicer is picked. It also keeps forgetting the Symbology contains a colour.3. Despite picking the correct field with the SA1 codes, which worked flawlessly in the previous version, the new version keeps throwing "The accuracy of your locations can be improved. Go to location type" error several times.
4. The heatmap symbology looks drastically worse than the previous version. The transparency effects are gone and it resembles a massive blob on the map.5. The maps go blank every time I re-open the report. The only fix I have found is to remove the value field and re-add the field to the visual to force a refresh of the visual.Things I have tried so far:1. Rebooted my system several times.2. Made sure my Power BI client is updated to the latest version.3. Cleared cache within Power BI We have business critical reports running using this map visual and it is extremely disappointing to see how they have released this version with the amount of bugs we have seen.
I would like to also raise this topic again.
Yesterday I noticed that the new visual has been updated again.... just to notice that it is causing even more trouble. For example, when selecting an area to filter other visuals, I noticed the selection is not consistent... for example, selecting an area in Brazil showed some entries in Germany, France, etc...
I think this is similar to the problem reported by Hoover_ODOT....
Basically this breaks completely my report....
I wish I had the chance to use the old visual version until the new version is tested and validated....
I am experiencing these bugs as well. The symbology settings reverting randomly and the inaccurate cross filtering are deal breakers as these are the reason I am using this visual. Looks like it's time for the developers to roll back to a stable version.
Thank you for posting this and sending the screenshots. We'll take a look at this to see what we can include in our release next month.
We're on the symbology settings reverting back as well as several other issues to be addressed in a release next month.
This release was a significant update, where we updated major components to improve performance, and so that we are set for a better future moving forward. We do a significant amount of testing and are working hard to handle the priority issues as they come in.
We will make sure to post a change log to show what's been fixed next month, and please keep letting us know what issues you are experiencing.
Thank you,
Andrew
I'm extremely relieved to see that I'm not experiencing similar issues in isolation. Specific concerns in my implementation:
Looking forward to the fixes. This is a critical functionality for our use-case.
Also having this issue - super frustrating! Any updates on this?
Thank you for reporting that, we'll take a look at the heatmap issue.
Symbology reverts should be addressed in the next release.
We're identifying and working through the most critical issues, targeting a release in November. We want to make sure to get as many showstoppers and high impact bugs taken care of, and need a little time to iron it all out.
Hi @Anonymous User Thanks for you reply.Can you give us a timeline when will all the above mentioned issues be resolved? Actually we have a client presentation coming and we can't deliver the project until all these issues are resolved.
We're looking to get the next release out in November, likely the 3rd week. The team is working hard on prioritizing all the issues and fixing as much as possible in this next update.
When is the release addressing Symbology reverts occuring?
Hi @EmilyHoltz
It should be in 2 weeks or so... we're very close!
I have been experiencing the issues in the OP's points one and two, as well as repeatedly getting the 'The accuracy of your locations can be improved..' message, till they fill the map. There is nothing more I can select (Points, One Country, Australia).
The issue with 'select one point from the map to filter other visuals on the dashboard' is very problematic as my team have come to value and use this feature. As present all of the maps my team use are not usable.
Screenshot shows point selected and resulting data shown in table below that no longer reflected selected point. Same issue occurs en masse if multiple points are selected. All maps produced no or published pre-update are affected similarly.
Has this been resolved? I'm still experiencing all of the same issues, but I'm not sure if it's because the fixes haven't been deployed by ESRI or because my corporate software admins haven't pushed an update.
Thanks for any feedback.
My issue related to the wrong visualization interaction filtering has been solved.
I checked last week, and it worked fine. I don't know about the other reported issues, but for my usage it is now finally working again as expected.
