I have an elevation raster (Ras1) and a polygon of the surface of the potential reservoir formed by the dam and a 450m contour.I used "extract by mask" to create a raster of the reservoir and reclassified this to a constant 450m (Ras2).I am now trying to create a raster (Ras3) that is identical to Ras1 apart from the area covered by Ras2, which should take the Ras2 values (450)I have tried using raster calculator an con([Ras1] > 0, [Ras1], [Ras2]) but the output is identical to Ras2, with no data from Ras1.Where am I going wrong with this? and is this even a sensible method?
Con ( IsNull ( [Ras2] ) , [Ras1] , [Ras2] )
10.x help links:
