hey ESRI community,
I created a survey using 123 Connect and needed to update the form with a few new rows. I went through all the documentation and wasn't able to republish the data; 123Connect just kept freezing. I was able to update this same survey before so I'm not sure what I'm missing here this time around. What I did so far was:
- Turned on the log from 123Connect settings
- changed the "ownerFolder" parameter in the files here
- rebooted 123 Connect
If anyone can explain the cause of this or a workaround solution that'd be awesome.
Hi. It looks like you originally published the survey from the web designer and then you made modifications in Connect. It is likely that Connect is not happy with the feature layer views created by designer. I suggest the following:
Connect does not handle well re-publishing of surveys previously authored in the web designer. It is generally best to do a Save As first and publish a new survey.
To clean things up, after you have published your survey again, you may want to go into your content and remove the old folder containing the original Form item, views and layers; just so you do not get things mixed up.
Thanks Ismael!
I just built out the form so there's no data to worry about at the moment.
