I've been messing around with equations to create bridge arches but I cannot figure out why one equation will not work in CityEngine.
I've been using Desmos graphing to figure out my equations and you'll see here that I have 3 graphs which I have designed to be similar lengths and heights:
- upward parabola
- downward parabola
- sine wave
I can successfully get the two parabolic functions to work under an extrude but I cannot get the sine wave to work under the extrude.
@Hidden
attr segment = 1
@Hidden
attr BridgeSpanL = geometry.du(0,unitSpace)
const Pi = 3.14159
const Bx = Pi/BridgeSpanL
@StartRule
BridgeSpan-->
set(BridgeSpanL, geometry.du(0,unitSpace))
split(u,unitSpace,0){~segment: BridgeArch(BridgeSpanL,split.index)}*
BridgeArch(BridgeSpanL,n)-->
extrude(
//-(pow(split.index,2)/BridgeSpanL)+split.index //Parabolic Curve for typical Arch Bridge
//pow((split.index-(BridgeSpanL/2)),2)/BridgeSpanL // Inverse Parabolic Curve
//(BridgeSpanL/4)*(sin((Pi/BridgeSpanL)*split.index))
(BridgeSpanL/4)*sin(Bx*split.index)
Although I can get a sine or cosine wave to work, I cannot get the period/frequency of the sine wave to behave as I expect under the function. If I could, I think I could create some more interesting arch patterns.
Is it my code, my math (probably), or is this a bug or a limitation of the extrude?
Parabolic Arch
Above: Parabolic equation working.
Flat Sine Wave
Above: Sine wave equation not working.
Above: Sine wave sort of working but without the a frequency parameter (Bπ or 1/Bπ)
Also, does Pi π have a built-in for CityEngine? I feel like it should.
