I am trying to have the folowing repeats hide/appear based on whether or not there is a record present (gm_lifestages_table, nr40_table, and reg_action_table). I cannot get them to reliably behave as expected despite using the attached syntax. Template and xls form are attached. Any help would be greatly appreciated!
In the template, your nr40_table is using the expression ${if (nr40_table | getValue:"count")>=0}. That may be a part of it.
What you are doing is very similar to what I was doing. I am surprised that you can actually parse this document successfully. After the recent update by esri, all my getValue:"count" for repeats were failing parsing. What I did was add Calculate fields inside my XLS to count the repeats, then I referenced those calculate fields inside the DOC.
Otherwise, you set-up looks good.
