Please suggest what is the procedure to create a dropdown checkbox to select multiple values from the table. I have created a dropdown list that shows customer status. Users can select the online status to reflect the record of online customer to the map as it is there are multiple statuses that can be select one by one.
Now, I want to create a checkbox with the dropdown list. User want to select multiple status at a time.
Please suggest or help me to find out the solution.
import React, { Component } from 'react';
import { Navbar, NavbarBrand, Nav, NavbarToggler, Collapse, NavItem,Dropdown,DropdownToggle,
DropdownMenu,DropdownItem,UncontrolledDropdown} from 'reactstrap';
import { NavLink } from 'react-router-dom';
import { authenticationService } from '../_services/authentication';
class Header extends Component {
constructor(props) {
super(props);
this.state = {
isNavOpen: false,
dropdownOpen:false,
south:null,
north:null,
central:null,
alarminfo:'',
status:false,
show:false
this.toggleNav = this.toggleNav.bind(this);
this.toggleDrop = this.toggleDrop.bind(this);
logout = () => {
authenticationService.logout();
toggleNav() {
this.setState({
isNavOpen: !this.state.isNavOpen // true
toggleDrop() {
this.setState({
selectLayer = (e) => {
let _this = this
if(this.props.loginRole.data.role === 'Admin'){
let customerQuery = this.props.item.customer.data
var query = customerQuery.createQuery();
let centerCustomerQuery = this.props.centerItem.centerCustomer.data
var centerQuery = centerCustomerQuery.createQuery();
let northCustomerQuery = this.props.northItem.northCustomer.data
var northQuery = northCustomerQuery.createQuery();
if(e.target.value === "clear"){
/* this.props.view.goTo({
target:[67.116733,24.898892],
zoom:14
let clearQuery = "status = 'Active'"
customerQuery.definitionExpression = clearQuery
centerCustomerQuery.definitionExpression = clearQuery
northCustomerQuery.definitionExpression = clearQuery
query.where = clearQuery
customerQuery.queryFeatures(query)
.then(function(response){
_this.setState({
show:true
_this.props.alarmInfo(_this.state)
centerQuery.where = clearQuery
centerCustomerQuery.queryFeatures(centerQuery)
_this.setState({
show:true
northQuery.where = clearQuery
northCustomerQuery.queryFeatures(northQuery)
_this.setState({
show:true
else {
//var queryExpression = `status = '${e.target.value}'`
var queryExpression = `alarmstate = ${e.target.value} AND status = 'Active'`
// South
customerQuery.definitionExpression = queryExpression
query.where = queryExpression
if (response.features[0].attributes.alarmstate === 0){
_this.setState({
alarminfo:'Online',
south:response.features.length,
status:true,
show:false
}else if (response.features[0].attributes.alarmstate === 1){
_this.setState({
alarminfo:'Powered Off',
status:true,
show:false
}else if (response.features[0].attributes.alarmstate === 2){
_this.setState({
alarminfo:'Link Down',
status:true,
show:false
}else if (response.features[0].attributes.alarmstate === 3){
_this.setState({
alarminfo:'GEM Packet Loss',
status:true,
show:false
}else if (response.features[0].attributes.alarmstate === 4){
_this.setState({
alarminfo:'Low Optical Power',
status:true,
show:false
}else
_this.setState({
alarminfo:response.features[0].attributes.alarminfo,
status:true,
show:false
// Central
centerCustomerQuery.definitionExpression = queryExpression
centerQuery.where = queryExpression
_this.setState({
central:response.features.length,
show:false
// North
northCustomerQuery.definitionExpression = queryExpression
northQuery.where = queryExpression
_this.setState({
north:response.features.length,
show:false
else {
let clearQuery = "1=1"
else {
render() {
return(
<div>
<Navbar color="dark" dark expand="md">
<NavbarToggler onClick={this.toggleNav} />
<NavbarBrand style={{color:'#1f91f3'}}>Transworld</NavbarBrand>
<Collapse isOpen={this.state.isNavOpen} navbar>
<Nav className="ml-auto" navbar>
<UncontrolledDropdown nav inNavbar>
<DropdownToggle style={styles.dropToggle} nav caret>
Customer Status
</DropdownToggle>
<DropdownMenu onClick={(e)=> this.selectLayer(e)} style={{background:"#343a40"}} center>
<DropdownItem value = "clear" style={styles.dropItem}>Clear Selection</DropdownItem>
<DropdownItem value='0' style={styles.dropItem}>Online</DropdownItem>
<DropdownItem value='1' style={styles.dropItem}>Powered Off</DropdownItem>
<DropdownItem value='2' style={styles.dropItem}>Link Down</DropdownItem>
<DropdownItem value='3' style={styles.dropItem}>GEM Packet Loss</DropdownItem>
<DropdownItem value='4' style={styles.dropItem}>Low Optical Power</DropdownItem>
</DropdownMenu>
</UncontrolledDropdown>
<NavItem>
<NavLink className="nav-link" to='/login' onClick={this.logout}><span className="fa fa-sign-in fa-lg"></span> Logout</NavLink>
</NavItem>
</Nav>
</Collapse>
</Navbar>
</div>
const styles = {
dropToggle:{
background:"#343a40",
color:"#1f91f3",
dropItem:{
color:"#1f91f3",
export default Header;
Regards,
Kawish
