Hello everybody.
I have a problem with field maps and survey123. I have a survey made in Survey123 connect of which i made a basic URL (arcgis-survey123://?itemID=xyz). I also have a webmap (arcgis online) where the data layer of this survey is added.
I open field maps on my android device, select the correct web map and add a geopoint at a location different from my current location. After this geopoint is made I get to see the URL. I select the URL which opens the Survey123 app and directs me to the correct survey. I fill in the survey and send it.
When i open the webmap op my pc i see that there are 2 geo points. point A is located at the location that i manually chose. It contains no data at all. Point B is located at my current location and it contains the data from the survey.
I dont understand why survey123 makes its own geometry and why the data from survey123 is not just simply added to the point made in field maps.
I have made multiple combined apps (field maps with survey123) and i have never encountered this problem. The URL is the same as in those apps.
Does anyone know where i am making a error and how to fix this?
Kind regards
-Daniel
