HI evertyone into community.
I'm in development of an Angular application.
With ArcGIS Pro I converted a CAD map into georeferenced FeatureLayer (with a spatial join between CAD layers) and I am able to load it on hybrid basemap.
Now when I click on layer I can see details of the selected polygon and my goal is to realize the reverse: select an attribute of layer and highlight it on the layer.
The problem I face regards the adaptation of JS sample code I can find into developer site to Angular source file.
Into attached image you may see the result of selection of a polygon on layer and the details of that item into the widget: now I would like to highlight as shown the polygon selecting it htorught the Text field.
I made some tests with
- query object
https://developers.arcgis.com/javascript/latest/sample-code/featurelayer-query/
- LayerSearchSource
https://developers.arcgis.com/javascript/latest/api-reference/esri-widgets-Search-LayerSearchSource.html#zoomScale
adding a search widget to viewmap
this.search = new Search({
view: this.mapView,
sources: [],
but getting an error when I try to modify the source attribute in following way:
this.search.source = [{...},...,{...}]
Any suggestion?
Any indication where to find good sample for my goal?
Thanks in advance and best regards.
