I'm working with a 3D Global View map in ArcGIS Pro for the first time, and there are two settings I'd like to change but can't figure out how to do:
1. Solution from here: ArcGIS Pro Global Scene Background
(In your global scene) You can change the black and star background by going to this setting: Scene Map properties-> Illumination->(uncheck) Show Stars and Halo. Now in General tab of the Scene Map properties set the colour of the background
2. According to the Extent Indicators help:
Extent indicators require two map frames—the map frame containing the extent indicator and the map frame with the extent you want to show—and only work with 2D maps. Because of this, the Extent Indicator button is disabled until there are at least two 2D map frames on the page.
Sounds like extent indicators are not supported in scenes?
I find myself again wanting to use extent indicators on a scene in a layout. It looks like this still isn't supported, but thought I'd check to see if anyone has come up with a clever workaround.
Thanks! The Illumination setting did the trick.
Too bad about the extent indicators.
