Our users need to collect data on Survey123 without mobile data connection. They need to have a basemap so that they ensure that the geopoint location is good (and not far away due to terminal GPS temporary mispositionning).
I would like to give them the opportunity of creating their own offline basemaps, because their collect area is wide, and it would be big data to store with the survey. I saw it was advised to create multiple forms but the collect area is so wide it would also be difficult.
I advised them to use TilePackage Kreator and copy the tpk on their terminal to use it on the field. The problem is that the tpk is not defined by default on the geopoint question, so they have to select it each and every time they collect a point.
Would it be possible for them, after creating a tpk and loading it on the terminal, to define it as the default basemap for the survey ?
Is there any other way for them to handle this operation ?
Should I post this as a Survey123 Idea ?
