Within web ADF applications, you cannot make local or Distributed Component Object Model (DCOM) connections to 10.1 sites. Local connections were previously used for the purposes of web editing and working with fine-grained ArcObjects. At ArcGIS 10.1 for Server, ArcObjects can be used to extend the server through Server Object Extensions (SOEs) without the need for a local connection. If you want to build a web editing application, you can use feature services in conjunction with the ArcGIS web APIs, the ArcGIS Viewer for Flex, and the ArcGIS Viewer for Silverlight.
Barry,You should be able to run the flex application from IIS on your local machine and point to services on the remote server. All that needs to be put in place is the cross domain file on the arcgis server to allow flash to talk to itRegardsAnthony
