Currently using Pro 2.7.0. Recently had some external changes where I remote in to my desktop at the office through either a VPN or Citrix and I definitely noticed non-ESRI issues with these changes. Curious if this is linked in some way so I wanted to double check.
See attached image!
Thanks!
May want to check and change the settings for the display: https://pro.arcgis.com/en/pro-app/latest/help/mapping/properties/display-options.htm on the ArcGIS Pro machine. I would review the following sections: Rendering quality, Rendering engine, Hardware antialiasing, Performance tips for virtual environments
Looks like same issue - only in Pro too. Catalog and ArcMap are fine. Also noticed this in attached image. Looks like pre-populated field is the issue.
Does the data look the same in a file geodatabase vs. Enterprise Geodatabase (if you have one) on terms of the table?There may be some settings for the display technology that may "improve" the issue. I am not sure of specific ones.
Okay, thanks. I was sort of afraid that would be the case.
That looks like a display issue, not a "table" issue. If you are remoting into your PC in your office, it could be how the data view is being rendered on your side.
