Hi, Is it possible to make the chart widget interact with the map? Eg when the map zooms the chart updates to reflect the map extent.
cheers
@RodWoodfordOld
Absolutely, just create a chart then create an action on that chart to filter the map (framework) and setup the common field between the chart and map data.
Equally, if you have an actin on the map when the extent changes, the chart will react accordingly too.
Thanks Jonathan for the help.
