Can somebody help me why https://www.arcgis.com/sharing/rest/content/features/generate is returning a html instead of json response in the attached code.
getting error - Unexpected token '<'
Chitra
Instead of providing code as an attachment, please add it using "Insert code sample". It makes it much easier to read your code and help you.
https://community.esri.com/t5/community-help-documents/how-to-insert-code-in-your-post/ta-p/914552
I have added the code through insertCode option. Thanks for letting me know.
Can someone help me why https://www.arcgis.com/sharing/rest/content/features/generate is returning a html instead of json response in the attached code.
const fileName=''; document .getElementById("uploadForm") .addEventListener("change", (event) => { fileName = event.target.value.toLowerCase(); }); //filepath is from local drive: D:\GIS\tl_2020_39_tabblock20.zip const portalUrl = "https://www.arcgis.com"; let name = fileName.split("."); name = name[0].replace("c:\\fakepath\\", ""); var params = { 'name': name, 'targetSR': this.map.spatialReference, 'maxRecordCount': 1000, 'enforceInputFileSizeLimit': true, 'enforceOutputJsonSizeLimit': true }; var extent = scaleUtils.getExtentForScale(this.map, 40000); var resolution = extent.getWidth() / this.map.width; params.generalize = true; params.maxAllowableOffset = resolution; params.reducePrecision = true; params.numberOfDigitsAfterDecimal = 0; var myContent = { 'filetype': 'shapefile', 'publishParameters': JSON.stringify(params), 'f': 'json' }; console.log(document.getElementById("uploadForm")); esriRequest({ url: portalUrl + "/sharing/rest/content/features/generate", query: myContent, form: document.getElementById("uploadForm"), handleAs: "json", load: lang.hitch(this, function (response) { if (response.error) { errorHandler(response.error); return; } var layerName = response.featureCollection.layers[0].layerDefinition.name; addShapefileToMap(response.featureCollection); }), error: lang.hitch(this, errorHandler) }); function errorHandler(error) { console.log('error!!'); } function addShapefileToMap(featureCollection) { let sourceGraphics = []; const layers = featureCollection.layers.map((layer) => { const graphics = layer.featureSet.features.map((feature) => { return Graphic.fromJSON(feature); }); sourceGraphics = sourceGraphics.concat(graphics); const featureLayer = new FeatureLayer({ objectIdField: "FID", source: graphics, fields: layer.layerDefinition.fields.map((field) => { return Field.fromJSON(field); }) }); return featureLayer; }); this.map.addMany(layers); };
is this in 3x or 4x?
I thought it was 3x because you are using handleAs, but passing a query. In 3x, it's content, not query.
But if you are using 4x, it's query, but you should use responseType, not handleAs.
we are using 3x.
I modified the code as below and getting a different error. Is my code correct?
{"error":{"code":405,"messageCode":"GWM_0005","message":"Method not supported.","details":[]}}
var layersRequest = esriRequest({ url: portalUrl + "/sharing/rest/content/features/generate", content: { 'f': "json", 'filetype': 'shapefile', 'publishParameters': JSON.stringify(params) }, handleAs: "json" }); layersRequest.then( function (response) { console.log("Success: ", response.layers); }, function (error) { console.log("Error: ", error.message); });
