Hi all,
We have been doing some PoC work with Field Maps and the team were confused why they couldn't create offline areas to someone else's map.
As an admin we expected to see all maps just like we can in ArcGIS Online/Portal but found we had to change the owner of the web map or to duplicate the map so it appeared in the My Maps list. Are we missing something?
As the team has a couple of admins, they want to be able to share the work of creating the offline areas, but found they couldn't. Also they can't manage the offline areas if that worker is not available.
If this is correct, then what work is being done to improve this? This is a huge limitation and really frustrated the newer users to the process.
Hopefully there is a simple workflow or button that we are missing. Look forward to hearing from the team.
Cheers,
Gareth
@AnaVilla
