Attached are 2 scripts that can help you when trying to fix services and/or determine what a service is being used for. Lift and extract pulls AGOL based data and drops it into a spreadsheet. It will show each map and where its data is coming from along with a lot of other useful data. MXD_pull_data copies the source MXDs out to a backup directory and digs through them pulling out each layers data source with the exception of Query Layers. Query layers are a nut I haven't cracked yet, but are pretty obvious when they show up.
Hi Chris,
I hate to say it, but, "it depends" on a few factors. Typically, the rule of thumb I share with folks is that they need to republish & check the configuration of the web app/map after a schema change just in case. I have seen instances where changes to the service are not picked up by ArcGIS Online/Portal web map. I have also see instances where it isn't a problem. In either event, it is always good to CYA when using referenced data.Likely this is not the answer you wanted or were seeking, but this is the local practice here typically.
