Sorry, the zip being missing is the same problem I had, but my ArcGIS Server administrator is the one who made the fix and all I know is what I wrote (that he had to increase the logpool size).I do know that the same problem can have other causes, like if you modified the original ESRI tool to use a different zip file name (I did that and it stopped working, so keep their default name), or the wrong network path being used to store the zip file, etc.Have you tried using firebug or fiddler or some similar tool to figure out what exactly is failing? In other words, what is the application trying to do on the back end that doesn't work?
Hello,Fisher!I encountered this problem too.But my problem is that everything is ok but when I clicked the save button, no extractdata.zip exists. Can you tell your solution in detail, such as the SDE 10, how did you solve it�?
