In 2.8 we can now duplicate label class. To save time, my idea is to allow copy/paste label class between maps.
For now, we have to create a new class, copy the label class, return to the feature label class and then paste all properties.
Couldn't agree more, I have two layers based on the same source with at least 8 symbol classes each. I set up 12 label classes on the one, but there's no way of getting them to the other without either redoing the symbology manually or creating 12 label classes one by one, copying and pasting the label properties one by one, and renaming them one by one.
@MarcelSt-Germain I believe this workflow would work better:1. Map with classes>>Contents Pane>>Right click the layer>>Shareing>>Click Save Layer File
2. Map without classes>>Geoprocessing Pane>>Apply Symbology from Layer tool input layer: layerNoClass
symbology layer: <Layer file saved>
Click Run buttonTools have a limitation for outputs being added to a single mapAlternatively, if you want to script something in python, you can use the arcpy.mp module to do this from a single map. https://pro.arcgis.com/en/pro-app/latest/arcpy/mapping/symbology-class.htm
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer gratis.
