I have a data frame in utm and a layer in WGS. When I open the attribute table and right click to calculate acres the calculation result is wrong if I use the default coord system of the data source. It's correct if I switch to the data frame. The results were off by almost half. I just upgraded from 10.6 to 10.7 arcmap desktop and never had this issue before. Is there a way to default to using the data frame coord system? Thank you in advance!
